- Fuel Gauge
Fuel Gauge
21 Nov 2017 23:39 #13
Replied by Warren Hampton on topic Fuel Gauge
How is the job coming along?11/21
- Gordie Meade
01 Nov 2017 18:52 #14
by Gordie Meade
Replied by Gordie Meade on topic Fuel Gauge
M-10 is in the shop to get the fuel flow meter installed. It should take about two weeks as the instrument panel (right side) has to be sent off to have the hole for the gauge laser cut.
- Scott Engelhart
26 Oct 2017 20:20 #15
by Scott Engelhart
Replied by Scott Engelhart on topic Fuel Gauge
I have looked at that instrument from EI also, look forward to hearing your report.
- Gordie Meade
24 Oct 2017 21:03 - 12 Nov 2017 16:53 #16
by Gordie Meade
Fuel Gauge was created by Gordie Meade
One of the few things I dislike about the M-10 is the lack of a dash mounted fuel gauge. The wing tanks have a sight gauge that is difficult to see in flight. And the fuselage tank has the float gauge that is easily in line of sight, but when it starts down you only have 30-45 minutes usable fuel left. I would really like more of a warning than that. Electronics International makes a fuel flow meter that has a number of features but the ones I am most interested in are fuel used, fuel left, and flow rate. It comes with a wiring harness and a flow transducer. I am looking forward to getting this installed and will get back here when I figure out how well it works. Hope it works as good as the one in the C152 I fly.
Last edit: 12 Nov 2017 16:53 by Gordie Meade. Reason: typo
