- Vacuum pump
Vacuum pump
- Gordie Meade
28 Oct 2019 18:02 #1
by Gordie Meade
Replied by Gordie Meade on topic Vacuum pump
The G5 IS STCed into the Mooney. Look under Univair, not Mooney.
28 Oct 2019 07:42 #2
Replied by Matt Gunsch on topic Vacuum pump
I guess I am stuck with steam gauges, my vacuum system can't fail, I have 2 venturies
- Jason Walleser
28 Oct 2019 06:52 #3
by Jason Walleser
Replied by Jason Walleser on topic Vacuum pump
I've considered the G5 and other modern options too. I didn't find the M10 on the G5's approved equipment list. The Aspen Avionics E5 caught my eye and lists the M10 in its STC. Still, I haven't really heard much feedback on the E5 from users.
The underlying reason I haven't immediately purchased it is that my family just grew, and I could use another seat. I thought I'd let the next owner choose his upgrades while not selling with inoperable equipment.
27 Oct 2019 21:36 #4
Replied by John Jones on topic Vacuum pump
When my vacuum pump fails I'm planning on removing the entire system and putting in a GRT Mini GA with the air data module and magnetometer. Tied into the Aera 660 it will save weight and gain a lot more capability.
- Gordie Meade
27 Oct 2019 20:13 #5
by Gordie Meade
Or remove the vacuum pump completely and install a Garmin G5. I did and have no more pump failures and a reliable certified horizon (EFIS) that is independent of mechanical issues.
27 Oct 2019 17:42 #6
Look at Note 3 of the Engine Type certificate, Vacuum Pump, CC rotation, so you are good to go.
