- Header tank issue
Header tank issue
- John Farrell
02 May 2021 13:07 #7
by John Farrell
Replied by John Farrell on topic Header tank issue
Thanks, Matt! Where to buy PRC B 1/2 or B2 fuel tank sealant?
02 May 2021 12:53 #8
Replied by Matt Gunsch on topic Header tank issue
You can try to remove the sealing compound on the outside of the tank and recoat it with PRC B 1/2 or B2 fuel tank sealant. DO NOT use RTV or JB weld.
- John Farrell
02 May 2021 00:54 #9
by John Farrell
Header tank issue was created by John Farrell
Might need either a new header fuel tank or repair. Logs show "pin holes" were found and repaired by "cleaning and sealed using REM-SEAL" in 2011. Now there is "seepage" coming from the area Does not appear to be a leak; however, the sealant apparently is weeping a little. Can the area be cleaned and resealed with RTV or some other sealant or do I need a new header tank? If new tank where do I look for one and what is the cost including installation?
