Glass gasolator gaskets.
  • Fernando Serra
08 Nov 2021 12:07 #1 by Fernando Serra
Replied by Fernando Serra on topic Glass gasolator gaskets.
I end up buying piper gasolator gaskets from spruce and they work great.
Thanks
14 Oct 2021 11:24 #2 by Ronald Raty
Replied by Ronald Raty on topic Glass gasolator gaskets.
I bought the cheap buna rubber gaskolator gaskets through Aircraft spruce. I don't remember which size (2" OD, or 2 1/8" OD), but it was just a bit too big. I forced it into the metal receptor and it had a slight wrinkle. But because it was rubber, it compressed and flattened out when I assembled everything. No leaks these past 2 years.
13 Oct 2021 22:51 #3 by Warren Hampton
Replied by Warren Hampton on topic Glass gasolator gaskets.
Take the glass to an Auto Supply house like NAPA. They can match you up. inside and outside dias will help . Lot of Coupes parts came from the auto business.
  • Fernando Serra
28 Jul 2021 15:19 #4 by Fernando Serra
Glass gasolator gaskets. was created by Fernando Serra
Posted on the non technical and got no replies so will try here. Does anyone have the part number(s) for the two gaskets (cork/rubber) used on the glass gasolator. Tried Univair but no luck. If you have a information about where to purchase will be appreciated as well. Someone said they are the same gasket(s) used on the piper gasolator?
