First Annual
12 Sep 2021 23:26 #1 by Matt Gunsch
Replied by Matt Gunsch on topic First Annual Fuel Pump Gaskets
the part numbers are in the list above
fuel pump gasket 643915
fuel pump bolt gasket AF766
the strainers in the tanks are a welded mesh and never need replacing
Aircraft are not like cars in that all the aircraft fuel filters are reusable after cleaning,
  • Robert James
12 Sep 2021 19:13 #2 by Robert James
Replied by Robert James on topic First Annual Fuel Pump Gaskets
Matt,
Do you have handy the Part Numbers for the fuel pump gasket gasket and fuel pump bowl gasket for the C90 16F engine in an Alon A2?
Also, do you ever have to change out the the inline finger fuel filters and header tank?
Thanks,... I’m about to do my first annual on an Alon that’s still new to me.
11 Sep 2021 22:53 - 11 Sep 2021 22:55 #3 by Matt Gunsch
Sorry I did not get back to this sooner, I have been on the road for work and got home at midnight last night,
there are a number of sources, Aircraft spruce is one,
AIR FILTER BRACKETT BA8805
Spark plugs Champion REM40E REM38S
OIL FILTER 48108-2 CH48109 (long)
Oil Screen crush gasket, large MS35769-48
Oil Screen crush gasket, small MS35769-11
Oil Press Regulator MS35769-18
OIL PICK UP TUBE MS35769-11 CRUSH GASKET
Last edit: 11 Sep 2021 22:55 by Matt Gunsch.
09 Sep 2021 18:45 #4 by John Farrell
Replied by John Farrell on topic First Annual
So, Matt, where do you get these items? Thanks for quick reply.
09 Sep 2021 17:42 #5 by Matt Gunsch
What everyone keeps on hand is different, in my case I always have several sets of fuel pump bowl seals, crush gaskets for oil strainer, spark plug gaskets, air filter,
no need to keep hoses for later use, get them when you need them.
09 Sep 2021 15:38 #6 by John Farrell
First Annual was created by John Farrell
Looking at my first annual for my 1948 ERcoupe:  N94865  415E S/N 4989.  Would like to order some miscellaneous hardware like screws, nuts, bolts, hoses, etc that I expect to replace.  I have seen some items on various Ercoupe websites like Univair, Spruce, and others.  Not sure at all on types and sizes of screws, bolts, nuts, etc.  Any  suggestions would be appreciated.   Thanks
