- Master Brake Cylinder Replacement
- Clayton Eveland
13 Sep 2022 10:45 #1
by Clayton Eveland
Replied by Clayton Eveland on topic Master Brake Cylinder Replacement
Thank you for the information. Can I purchase a copy of your drawings? I am curious how they did the brake and steering set up.
- Jeff Shackelford
13 Sep 2022 10:31 #2
by Jeff Shackelford
Replied by Jeff Shackelford on topic Master Brake Cylinder Replacement
I have rudder pedals and toe brakes on my F-1A. My nose gear does not steer with the yoke, true rudder pedal steering. They say mooney on them. I have all the blueprints for the installation also. I don't know how rare this is, but I haven't seen another coupe with them.
- Clayton Eveland
27 Aug 2022 11:34 #3
by Clayton Eveland
Dumb question, has anybody ever put toe brakes on a 415-D?
- Dana Pyle
24 Aug 2022 10:18 #4
by Dana Pyle
Replied by Dana Pyle on topic Master Brake Cylinder Replacement
I’m looking for what would be the correct master cylinder for the Cleveland brakes,I believe I have old style fatter cylinder with Cleveland setup ,sorry don’t know how to post a picture here
- Bruce Bennett
19 Sep 2021 21:20 #5
by Bruce Bennett
Replied by Bruce Bennett on topic Master Brake Cylinder Replacement
Sorry for the late reply. Vacation.
My Scott master cylinder went bad so I replaced it with the Alpha Aviation unit
on the recommendation of a friend who had previously done the swap. Pretty
straight forward. It is critical to make sure the master cylinder shaft can extend
fully and is not impeded by the brake pedal. The unit is actually a Matco unit
and failure to allow the shaft to fully extend is a bad thing. Works great with the Goodyear brakes on my 415C.
- Scott Monroe
14 Sep 2021 16:56 #6
by Scott Monroe
Master Brake Cylinder Replacement was created by Scott Monroe
Greetings, has anyone installed the Alpha Aviation Ercoupe Brake Master Cylinder replacement? I am concerned that since the lower attachment point appears to be round that it will not fit into the lower slot. Any comments will be appreciated. Thank you. Scott
