Correct Tachometer Cable for 415-C w/C-85
30 Oct 2021 23:39 #1 by Warren Hampton
Replied by Warren Hampton on topic Correct Tachometer Cable for 415-C w/C-85
Shawn, $13.31 sound like the inner cable only. I have both starter an both !5 amp and 35 Amp gens when you need them $$ have no idea what they are going for. Warren
The following user(s) said Thank You: Shawn DUFFEE
  • Shawn DUFFEE
23 Oct 2021 16:10 #2 by Shawn DUFFEE
Replied by Shawn DUFFEE on topic Correct Tachometer Cable for 415-C w/C-85
Hi Matt,
My apologies, I should have stated this is for my restoration Ercoupe. It came without an engine. The C85 I found had no starter, no generator, no tach cable.
So, I am not replacing one, I just need one, period. That's why I can't even determine rh or lh thread, length, etc.
The engine is on a test stand 30mi away from the fuselage.
Sorry for the confusion.
23 Oct 2021 15:57 #3 by Matt Gunsch
Replied by Matt Gunsch on topic Correct Tachometer Cable for 415-C w/C-85
are you sure you need to replace the cable ? it might need to be cleaned and re-lubed, disconnect it at both ends and remove the core, clean the core, spray solvent thru the housing and then dry, lube the cable and reinstall.
  • Shawn DUFFEE
23 Oct 2021 10:35 - 23 Oct 2021 10:36 #4 by Shawn DUFFEE
Thanks Matt.
when I copy the part number and search Univair shows this $13.31 part. I think the only other part I have seen at Univair that cheap was a washer....Is that all I need? When compared to the 5 that show up in the link you shared, it is roughly 1/10th the price...
I've never had to buy a tach cable before, they were always there already. I had no idea there was so much to consider.
Thank you!
Last edit: 23 Oct 2021 10:36 by Shawn DUFFEE.
22 Oct 2021 23:41 #5 by Matt Gunsch
  • Shawn DUFFEE
22 Oct 2021 12:58 #6 by Shawn DUFFEE
Correct Tachometer Cable for 415-C w/C-85 was created by Shawn DUFFEE
Hello All,
Can anyone please supply the correct tachometer cable part number or length & lay for a 415-C with a Continental C-85?
Thanks, in advance!
Shawn
