- Fuel line hose clamp torque
02 Feb 2023 19:46 #1
Replied by Ronald Raty on topic Fuel line hose clamp torque
An interesting question, I had to look it up:
BREEZE Mini Clamps
These are typically worm drive hose clamps found on small rubber and plastic lines ranging in size from 1/4" to 3/8" diameter. The proper torque for these is 10-15 in. lbs.
Breeze Mini Clamps
BREEZE Power-Seal and AeroSeal Worm Drive Hose Clamps
These are found in sizes from 7/16" to 7" in diameter. The correct torque is 30-45 in. lbs. for the stainless screw versions and 27-35 in. lbs. for the carbon screw versions.
BREEZE Mini Clamps
Breeze Mini Clamps
- Donato Martino, CFI-S
02 Feb 2023 19:23 #2
by Donato Martino, CFI-S
Fuel line hose clamp torque was created by Donato Martino, CFI-S
Can anyone post the torque values to tighten hose clamps?
Thanks
Thanks
