Engine Data Plate Change
08 Jun 2023 23:56 #1 by Warren Hampton
Replied by Warren Hampton on topic Engine Data Plate Change
Fresno plates need a lot of stamping, Ware as other on the net for C85s need less. Most upgrade I have seen are 85 stamped over the 75. Plus, check casting number on the intake web block My brother got dragged in on one that was still for a 75 it had got wrecked and FAA was looking for why.
  • Edward Moore
17 May 2023 00:13 #2 by Edward Moore
Replied by Edward Moore on topic Engine Data Plate Change
PS:
Since its your first annual, etc, your mechanic may not be familiar with the process of changing a data plate. Suggest he call DIVCO, and discuss procedure - they have to do it when changing an engine case that is beyond repair, etc. Just explain to them reason - it's not a teardown. 2c
  • Edward Moore
16 May 2023 23:58 #3 by Edward Moore
If all you need is a new correct/updated data plate. Check with FRESNO, if IIRC, I think they use to advertise the blanks ( they looked just like the OEM). You can use the dies and stamp appropriately and, of course, note in engine lob book with justification.
Years ago, if one had a damaged one, IIRC, that "TCM", would provide a replacement but required a letter from FAA authorizing.
FWIW
  • Jerome Carncross
16 May 2023 19:05 #4 by Jerome Carncross
Replied by Jerome Carncross on topic Engine Data Plate Change
There are entries in the logbook for the carb upgrade (Marvel Schebler) and retuning for 85 hp.  Subsequent entries continue to identify as C-75.  But the prop has been shortened to 69.5 " and the engine turns 2450 rpm in cruise.
16 May 2023 18:26 #5 by Larry Snyder
Replied by Larry Snyder on topic Engine Data Plate Change
How did you discover the upgrade? There’s no visible difference except for the data plate.
  • Jerome Carncross
16 May 2023 18:21 #6 by Jerome Carncross
Engine Data Plate Change was created by Jerome Carncross
During my first annual inspection on my 1947 415C we have found the engine has been upgraded to 85 hp.  However, the Type Certificate and the specified Service Bulletin (M47-16) indicate the engine data plate has to be changed to C85-12F with the existing serial number.  Continental Motors will not make a new data plate for the upgrade.
Does anyone know of an alternative to this situation.  My A&P/IA is reluctant to sign off on the current configuration.
Thank-you
