- Fuselage skins
Fuselage skins
30 Jul 2025 09:11 #1
Replied by John Jones on topic Fuselage skins
You mentioned that one of the parts replaced was the right side boot cowl. Looking at the parts manual those are listed as F-13060 vs. F-13040 so it's possible the part numbers were entered incorrectly. Was there a verbal description for them as well as the numbers?
29 Jul 2025 14:03 #2
Replied by Warren Hampton on topic Fuselage skins
Try Ercoupe numbers
- Frank Hamelly
08 Jul 2025 09:25 #3
by Frank Hamelly
Replied by Frank Hamelly on topic Fuselage skins
Here are the skins in question. Need their locations/names please: F-13040, F-13147, F-13058-1. Thank you in advance! Mike.
04 Jul 2025 00:40 #4
Replied by Matt Gunsch on topic Fuselage skins
it might help if you give us the part numbers
- Frank Hamelly
27 Jun 2025 17:21 #5
by Frank Hamelly
I have the Forney Parts manual. The skins listed in the logbook for the repaired damage do not coincide at all with the parts manual.
19 Jun 2025 12:12 #6
Forney part numbers are the same as Erco part numbers but with 415- replaced with F. you can look at the factory drawings on Ercoupe.info to get the part numbers.
The following user(s) said Thank You: Kenneth Crofut
