Rib Stitching
  • Dale Kohler
09 Jul 2020 20:44 #7 by Dale Kohler
Replied by Dale Kohler on topic Rib Stitching
Matt,
Do you have fabric covered wings?
Are the trailing edges stiched on your plane, if it is fabric?
What is Cam that you are refering to?
Thanks.
06 Jul 2020 13:36 #8 by Matt Gunsch
Replied by Matt Gunsch on topic Rib Stitching
for the spacing and tie off distances, that would have been laid out in CAM 18, which should be the same as AC43.13
  • Dale Kohler
05 Jul 2020 19:58 #9 by Dale Kohler
That is what I said, as the oem specified.
My question, is to whom ever reads this, is your wings rib stitched?
Just a overall question to what ever system is used. I know it is required.
I am amazed that the time frame 1967 to 1994 no one notice that these wings where not stitched.
Also, the service manual does not specify how often you should tie off. Unless I missed it.
05 Jul 2020 18:39 #10 by Michael Hainen
Replied by Michael Hainen on topic Rib Stitching
The following is from the Q&A section of the Oracover 6000 site.
Is rib stitching required?
That just depends on the requirements as set forth by the designer of your aircraft. If the plans call for rib stitching, then you must rib stitch. If the plans call for rivets, you will use rivets.
  • Dale Kohler
04 Jul 2020 05:37 #11 by Dale Kohler
Larry,
Are your wings laced on the trailing edge?
Thank You
  • Dale Kohler
04 Jul 2020 05:18 #12 by Dale Kohler
That sounds like an excellent Idea! Thank you. I will do that.
