- Brake actuator
Brake actuator
- Wayne Eleazer
08 Oct 2019 10:23 #1
by Wayne Eleazer
Replied by Wayne Eleazer on topic Brake actuator
Not all of the Ercoupes had the T handle. Routing that cable between the T handle and the brake pedal can be "fun", especially when you found it slipped into the wrong place and you have to take things back apart to attach it properly.
BY THE WAY! The nut on that T-handle behind the panel can cut into the wire going to the ammeter and cause a huge electrical short. Strongly recommend you re-route that section of wire to above the T-handle so to eliminate that possibility.
Good Luck!
Wayne
Good Luck!
Wayne
- Gene deRuelle
03 Sep 2019 12:58 #2
by Gene deRuelle
Replied by Gene deRuelle on topic Brake actuator
Thank you, but I have one and I finally read it. It shows just what I wanted Thanks again
02 Sep 2019 21:05 #3
Replied by Lawson Laslo on topic Brake actuator
Do you have a service manual? I can email you a pdf of one if you need one
02 Sep 2019 21:04 #4
It had a brake pedal on the floor board and there was a t handle parking brake linked to the pedal
01 Sep 2019 10:00 #5
Replied by Larry Snyder on topic Brake actuator
Both.
- Gene deRuelle
01 Sep 2019 09:56 #6
by Gene deRuelle
Brake actuator was created by Gene deRuelle
I'm new to the Ercoupe and have just purchased a 415 completely disassembled. Its like a giant puzzle. Question: was the brake on the rudderless models actuated by a T handle on the instrument panel or a pedal?
