Ercoupe fuel pump parts
11 Feb 2020 13:15 - 11 Feb 2020 13:16 #1 by Jeffrey Tipton
Replied by Jeffrey Tipton on topic Ercoupe fuel pump parts
If you do not need the full kit, Aircraft Spruce also has the AF766 bolt gasket $1.32 and the 643915 gasket for $12.85.
Part number listing can be found in FAA AD 81-07-06
Last edit: 11 Feb 2020 13:16 by Jeffrey Tipton.
09 Feb 2020 22:01 #2 by Ronald Raty
Replied by Ronald Raty on topic Ercoupe fuel pump parts
You can get a kit AF-6561 kit from Aircraft Spruce. It includes: fuel pump screen, TCM P/N 643913; cork cover gasket, TCM P/N 643915; bolt gasket P/N af766(643914). AS has the individual gaskets, also.
If you need other rebuild components (such as a diaphram), you can get a rebuild kit FPA 28/29 (not PMA!) from "Then and Now Automotive". These fuel pumps were used on a variety of cars in the 40's
  • Kathy McMurray
09 Feb 2020 12:53 #3 by Kathy McMurray
Ercoupe fuel pump parts was created by Kathy McMurray
I need part numbers for the two gaskets for the top bowl of the Ercoupe fuel pump. One gasket (currently rubber) goes under the AN4 bolt that holds the top to the pump and the larger gasket (currently cork) goes between the top and the pump. The parts manual doesn’t mention the pump and I can’t find any references online.
