- mysterous bellcrank
mysterous bellcrank
02 Nov 2020 19:09 #1
Replied by Lawson Laslo on topic mysterous bellcrank
- Morris Pearson
28 Oct 2020 18:09 #2
by Morris Pearson
Replied by Morris Pearson on topic mysterous bellcrank
Don't know for sure but it sounds like a bellcrank for a panel mounted brake handle.
- Michael Hainen
12 Oct 2020 04:16 - 12 Oct 2020 06:17 #3
by Michael Hainen
Replied by Michael Hainen on topic mysterous bellcrank
If you have a pull starter knob, my best guess is, it probably is the starter bellcrank. You pull the knob and the bellcrank pushes the rod/ bendix gear to engage engine and pull a little more it pushes an old fashion start button, Right off 1930's farm tractors and early combines. Always make sure the knob returns to position or the gear will still be engaged.
Last edit: 12 Oct 2020 06:17 by Michael Hainen. Reason: grammar
- Kevin Gassert
10 Oct 2020 21:06 #4
by Kevin Gassert
Replied by Kevin Gassert on topic mysterous bellcrank
Hard to say. Only bellcrank there would normally be hand brake. Can you upload a picture?
Kevin
Kevin
- Gene deRuelle
22 Sep 2020 20:21 #5
by Gene deRuelle
mysterous bellcrank was created by Gene deRuelle
In getting some really gucky reside from the back side of the firewall, I ran across a bellcrank that I cannot explain. It's about 4" on the long arm and 2" on the short one. It's mounted parallel to the firewall. It has a foot long threaded rod attached to the short arm. Travel is about two inches. Can anyone tell me what this is? What it operates? Call me at 775-200-6519. Thanks a bunch
GeneD
GeneD
