- Braided Battery ground strap
- cubvarga
17 May 2016 08:09 - 17 May 2016 08:14 #1
by cubvarga
Replied by cubvarga on topic Braided Battery ground strap
You will find what you need at aircraft spruce. Look under wire-sleeving-heat shrink. You will find Tinned Copper Braid for battery ground terminals and end plates to solder on to braid.TKS....
Last edit: 17 May 2016 08:14 by cubvarga.
- meyer712
16 Dec 2015 23:59 - 17 Dec 2015 00:00 #2
by meyer712
Braided Battery ground strap was created by meyer712
I am in need of a replacement battery ground strap. I went to take the battery out for the winter and found massive corrosion on the negative terminal. The strap just fell apart at the connection. I purchased a new battery exactly like the one that was in it. But where can I find a braided ground strap?? Any ideas or part numbers It was a flat strap about 1 inch wide and was flat on both ends with a hole in each end. Not sure of the size of hole but it will fit on the stud of the battery. Any ideas?? Ercoupe 1948 415 E model.
Last edit: 17 Dec 2015 00:00 by meyer712. Reason: additional info
