magnetos ercoupe
  • 10149
04 Feb 2016 08:28 #1 by 10149
Replied by 10149 on topic magnetos ercoupe
I suggest:
Velocity Shoppe
El Reno, OK
405 413 4972
He is great with Eismann mags.
Have also used him in the past to repair some carburetors.
Jim Accuntius
Georgetown, TX
01 Feb 2016 05:28 #2 by Lynn Nelsen AP/IA
Replied by Lynn Nelsen AP/IA on topic magnetos ercoupe (Eisimann)
EOC tech support-Marvin Dunlap in Hamburg MI can help with that issue. His number is 810-923-0922 or This email address is being protected from spambots. You need JavaScript enabled to view it.
I recommend contacting a technical adviser instead of asking on the message board because you are more likely to get a good answer quickly.
Lynn
  • cubangyro
30 Jan 2016 18:53 #3 by cubangyro
magnetos ercoupe was created by cubangyro
Need information, where, how to check or repair Eisemann magnetos LA-4 , I removed they look in good condition but need to check , Engine has 31 hrs since Overhaul but no information on the magnetos on the Logs
