- window lock
window lock
- 10109
14 Sep 2016 16:48 #1
by 10109
Replied by 10109 on topic window lock
All you have to do is grind a little under where the shank of the lock goes between the two ears on each side of the window. I had to do that and now a good padlock will go in. Regards, Larry
- dburques@trinity.edu
06 Sep 2016 08:36 #2
by dburques@trinity.edu
window lock was created by dburques@trinity.edu
It's a trivial question, but I wonder if there is a lock with a flexible shank that can be used to secure the windows when parked away from my home airport.
