- Fuel pump replacement
- Dennis Newbury
14 Apr 2021 22:48 - 14 Apr 2021 22:57 #1
by Dennis Newbury
Fuel pump replacement was created by Dennis Newbury
Good evening to everyone. I hope someone can chime in.
I have a 46 Ercoupe 415-c with a C85-12 engine. My fuel pump diaphragm started to leak so I have to buy an overhauled Fuel Pump. My question is: currently installed is a C75 Fuel pump according to the stamped number on the pump installed on my Ercoupe. Should I replace the pump with what I have installed or replace it with the correct Fuel pump for my engine? The C75 Fuel pump currently installed on my plane says it has 5-7PSI and the C85 Fuel pump has 3.5-4.5 PSI.
I don't know if the current pump installed on my plane, although stamped says it's for a C75 has or hasn't been rebuilt to be for a C85-12 engine. The arm's are the same for the C75 and C85 so I understand.
Anyone have experience or first hand knowledge on this subject? Greatly appreciate it and look forward to your responses.
Blue Skies,
Dennis
Blue Skies,
Dennis
Last edit: 14 Apr 2021 22:57 by Dennis Newbury.
