- Rudder pedal kit to purchase or rent
23 May 2023 18:25 #1
Replied by Warren Hampton on topic Rudder pedal kit to purchase or rent
Ebay does not show Cabels nor cable cover that are needed. Side note Robert see June 2019page 3 about 3800H top left corner.
- David Gilson
21 May 2023 09:52 #2
by David Gilson
Replied by David Gilson on topic Rudder pedal kit to purchase or rent
There is a set on ebay, I really don't know anything about them, but 5ake a look.
21 May 2023 00:12 #3
Cables go over the floor board Steve Balla in Fallbrook I gave the set I took out of my E mod. This email address is being protected from spambots. You need JavaScript enabled to view it. The mount on the toe board face
simple change.
simple change.
18 May 2023 22:35 #4
Replied by Matt Gunsch on topic Rudder pedal kit to purchase or rent
it is thru the spar web, not the spar, there are a number of holes thru the web.
17 May 2023 23:22 #5
Replied by Ronald Raty on topic Rudder pedal kit to purchase or rent
The kit I have seen requires drilling holes through the main spar to run the cables. I would be curious if anyone knows of any that don't require holes in the spar.
- RPJ
16 May 2023 22:26 #6
by RPJ
Rudder pedal kit to purchase or rent was created by RPJ
Looking to add a rudder pedal kit to my 415CD so I can get my three control license.
