- Wood prop
Wood prop
- Charles Dicey
25 Jun 2024 17:31 #19
by Charles Dicey
Replied by Charles Dicey on topic Wood prop
I have one sitting right here,a sensenich 72-48 weight is right at 9.5 lbs
25 Jun 2024 17:18 - 25 Jun 2024 17:25 #20
Replied by Warren Hampton on topic Wood prop
Who knows the dif in weight between Alum and wood props? If engine stoppage which would cause more drag? Larry you were talking about wings made me thing About 2000 there was a guy trying to get a new wing design going for Coupes wonder what ever became of that.
Last edit: 25 Jun 2024 17:25 by Warren Hampton. Reason: moe to add
25 Jun 2024 17:00 #21
Well not being an Engineer. I cannot believe ERCO would want to loose anything using a small engine like C85. Wood props were less used by general aviation... Pitch and RPM has more to do with pulling than how long the prop is. And there is an efficiency dif between wood and Alum props also thin vs a club.
25 Jun 2024 10:27 #22
Replied by Ronald Raty on topic Wood prop
I have seen some arguments that upgrading the engine C-75 to C-85 doesn't gain you much if you have to change to a shorter propeller. The C-75 allows a larger diameter propeller (73, I think), so going to a C-85 may give more HP, but a smaller propeller (71 inch) with less lift area doesn't give much additional thrust. A wood propeller can be as large as 74" diameter.
This all assuming I am reading the Type Cert correctly.
24 Jun 2024 21:19 - 24 Jun 2024 21:24 #23
larger jets require a larger venti + more fuel more air. Just basic stuff Contact Vern see if he has an C85 carb. Mac, I am going to look see if I have a good 71 with a 51 pitch. I know I have 48 and 49 there is no change in weigh...
Last edit: 24 Jun 2024 21:24 by Warren Hampton. Reason: more to say
24 Jun 2024 20:33 #24
Replied by Larry Snyder on topic Wood prop
The carb change assumes a Stromberg. I’m not sure you can make the coupe light enough to make a noticeable difference in its glide. The fat wing pretty much precludes “soaring”. My best glide is 80. Basically, you just have to get used to that green circle around your plane in ForeFlight being real close…
