Header tank
10 Aug 2016 04:54 #1 by Lynn Nelsen AP/IA
Replied by Lynn Nelsen AP/IA on topic Header tank
I believe that 5 gal header tanks are no longer available. I recommend you have one made. This has worked well for others. Advisory Circular (AC) 23-27 dated 5/18/09 discusses how parts for Vintage Airplanes can be manufactured under the owners direction. If you take your old tank to a good welding/fabrication shop, they can weld a new tank using the same stainless steel material as was used in the original tank. If the old fittings are in bad shape, new ones can be obtained from Skyport. Call me if you have any further questions. Lynn 863 635 7916
  • 10112
07 Aug 2016 02:47 #2 by 10112
Header tank was created by 10112
Look under "Advertisers" above - Precision Services, probably your best bet unless someone has one left over from a conversion>
