- 415-C Side windows info
03 Oct 2024 11:53 #7
Replied by Brooks McNew on topic 415-C Side windows info
Yeah they do crack easily... I needed three windows to replace mine because I cracked one!
I borrowed a tip from the Vans RV builders that worked perfectly. When you squeeze the soft rivets they can expand a bit and crack the drilled hole. So I match drilled the holes at 1/8" with the frames, then removed the frames and upsized the holes to 5/16" so the rivets wouldn't actually touch the plastic. Used "plasti drill" bits which cut through the materiel like butter.
03 Oct 2024 11:17 #8
Replied by Ronald Raty on topic 415-C Side windows info
Plexiglass is a brand name for acrylic plastic. They are the same thing. The choice for glazing is typically acrylic (Plexiglass) vs polycarbonate (Lexan). From what I remember, Polycarbonate is more flexible so it is less likely to crack while forming to the curves of an Ercoupe or when drilling. It is also easier to scratch.
- James Davis
03 Oct 2024 03:01 #9
by James Davis
Replied by James Davis on topic 415-C Side windows info
I will order from Vernon. I always do.
03 Oct 2024 02:56 #10
You can call LP Aero directly, I just got mine through Vernon so he gets his commission. I also got the tinted windows. They offer clear, grey tint, or green tint. Same price for any color.
- James Davis
03 Oct 2024 01:47 - 03 Oct 2024 01:47 #11
by James Davis
I am just trying to find out where I can get a little tinted version of the side windows. I'll take care of the riveting. All I need is the Plexiglass or Acrylic pieces.
Yes, I'll talk to Vernon but I just wanted to give him a little time because last time I talked to him he mentioned they were having really heavy rain due to hurricane Helene and water was getting into his shop. I don't know if he is dealing with some level of flooding. Didn't want to bother him just after that. He may have been busy with cleanup!
Last edit: 03 Oct 2024 01:47 by James Davis.
03 Oct 2024 01:24 #12
Talk to Vernon about the wobbly channel. He can also have windows shipped to you from Aero Plastics. They're reasonably priced if you're willing to unrivet and re-rivet the top and bottom frame from your old windows into your new windows. It's pretty easy (I just did this myself) because they're soft-type rivets.
If you want complete window assemblies with the top and bottom frame already installed... That's also available but significantly pricier.
